Home > Maintenance & Modifications > Door theft protection,
Page 2 of 2 <12
Dave-H
GUM97 wrote:
Ric wrote:
What size balls do you have? Thumbs Up
Ooh, well thats a bit forthcoming isn't it Laughing Rolling with laughter
Laughing didn't know this doubled as a f*** buddy site !!
I used 5mm BB's Wink Guns and Landrovers .... anything else is irrelevant.
Post #196679 27th Dec 2012 3:56pm
Ric
Yes Dave, you've been missing out!
And thanks for the 5mm info Very Happy its only a car!
Post #196739 27th Dec 2012 6:06pm
orhdpos
Part of my layered approach, I've brought some of them scaffold eyes the things that secure scaffold to a building, well they are rated to take 1250KG and have M18 fitting a few of them in the garage concrete floor for ground anchors and a couple more in the lintel to take scaffold tube which you slot up and drop into 50mm dia holes in the concrete floor, secured with a couple of padlocks so they cant be removed, means landy cant be move from the garage without going through scaffold tube or cutting pad locks, and secured underneath with ground anchors, thing is you can pick them up with a fixing for about £15 each so 4 £60 cheaper than a purpose made ground anchor, you have 4 things to be cut through hard to use a angle grinder under a lany in a confined space like a garage.
It all helps
Orhdpos Bow down
Post #196768 27th Dec 2012 7:26pm
It all helps
Orhdpos Bow down
As part of a layered approach that's a good idea. I suggest stuffing a length of rebar down the scaff tube and filling it with concrete, since it would be easy enough from your description to cut the tube in well under a minute without a sound. With concrete and rebar, it's still under a minute but noisy.
A 4.5mm ball will fit fully in the recess in the screw head. A 5mm won't bottom out but might go in if you belt it!
Post #196795 27th Dec 2012 8:06pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
Thats a cracking idea k9f
i will have to get some bb fitted once i have stainless screws fitted 2004 TD5 Defender 90 xs station wagon
Post #196808 27th Dec 2012 8:30pm
K9F
Thanks but before you ask how big my balls are here's a picture to satisfy anyone's curiosity..... Rolling with laughter
Shocked Shocked Google 'big balls' and there's pictures there that will give you nightmares for weeks.... Shocked Shocked If you go through life with your head in the sand....all people will see is an ar5e!!
Post #196913 28th Dec 2012 10:48am
WarPig
I decided to fit heavy duty security posts, the front one is telescopic and the side post that boxes the landie in is a lift out post. Doesn't prevent door theft though...
Post #197775 31st Dec 2012 2:19pm
JWL
I clicked on one of those youtube links, I knew I shouldn't have but you know what curiousity is like. I am traumatised but as you say I only have myself to blame Sad
Post #197777 31st Dec 2012 2:27pm
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
That ford looks pretty vulnerable though.
Post #197778 31st Dec 2012 2:28pm
Tiger
I use a post and another vehicle to block mine in
Post #197780 31st Dec 2012 2:35pm
YeomanOfTheBar
United Kingdom 2013 Defender 110 Puma 2.2 DCPU Santorini Black
Is the red top part of the security system too? Electrified gates perhaps? Twisted Evil 2013 Defender 110 XS DCPU
Post #197810 31st Dec 2012 3:59pm
WarPig
Your right, but I couldn't care less about the Ford as its a company car. And it's not mine Mr. Green
Post #197843 31st Dec 2012 5:23pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
A 4.5mm ball will fit fully in the recess in the screw head. A 5mm won't bottom out but might go in if you belt it![/quote]
Sometimes it's better to let the inner bar / tube to spin and be free moving as when some tries to cut it, it constantly turns making cutting far harder as it jams the blade
It's what I did on my window guards on my van It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #197848 31st Dec 2012 5:33pm
Nicking doors is perhaps not a new thing...
Post #304347 2nd Feb 2014 12:13pm
Page 2 of 2 <12
