Home > Technical > Engine Temp
jst
Engine Temp
i know its cold of late, well -2 or so around here last two mornings.
quick question, in a 11 MY puma, when sitting in slow moving/queuing traffic (<10mph) for 5 to 10mins and with the fan on speed 1, temp on max, does the engine temp go down from normal in your Puma?
this is after engine being up to 80-84 deg for 5 - 10mins of driving. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #189833 30th Nov 2012 5:53pm
K9F
08 90XS I have a Scangauge and when stationary after a run the temperature will drop by about 4-6 degrees quite quickly even in the Summer months. It runs at about 90 degrees normally 'on the go.' In slow moving traffic though I find generally it only drops by about a degree or so as you are still periodically placing load on the engine. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #189873 30th Nov 2012 7:34pm
rossy
If its any consolation jst I asked the same question ( on the forum) last year whilst I was parked outside the chemists waiting for the missus in -5. The heater was on full blast and the temp gauge gradually plummeted towards cold. Bottom line is that this vehicle needs to be moving for the heater to work properly when its really cold outside !
Post #190413 2nd Dec 2012 10:16pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
Quite normal, nothing to worry about, just a PITA when stationary for a while and it's cold ! 2007 TD5 90 Hard Top
Post #190429 2nd Dec 2012 10:59pm
jst
ok, cheers for the replies. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #190544 3rd Dec 2012 11:58am
