Home > Technical > Engine Temp |
08 90XS I have a Scangauge and when stationary after a run the temperature will drop by about 4-6 degrees quite quickly even in the Summer months. It runs at about 90 degrees normally 'on the go.' In slow moving traffic though I find generally it only drops by about a degree or so as you are still periodically placing load on the engine. If you go through life with your head in the sand....all people will see is an ar5e!!
30th Nov 2012 7:34pm |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
If its any consolation jst I asked the same question ( on the forum) last year whilst I was parked outside the chemists waiting for the missus in -5. The heater was on full blast and the temp gauge gradually plummeted towards cold. Bottom line is that this vehicle needs to be moving for the heater to work properly when its really cold outside !
2nd Dec 2012 10:16pm |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 |
Quite normal, nothing to worry about, just a PITA when stationary for a while and it's cold ! 2007 TD5 90 Hard Top
2nd Dec 2012 10:59pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7703 |
ok, cheers for the replies. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
3rd Dec 2012 11:58am |
