![]() | Home > Technical > Battery terminal |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
Lee,
give Tim @mobilecentre a call, he's you man for all thing leccy ! |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
Could you not use the threaded hole on the opposite side. I put an extra bolt into it on mine but not had a use for it as of yet. Providing the wiring you are putting in isn't gigantic then it should be okay to add to what you've already got there. I have my spot light feed and amp on that very connection and the Amp power feed cable is 4 gauge 80A or something like that. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645
It is a bus bar type extension
