Home > Technical > Battery terminal
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Battery terminal
This is on the + terminal on MY12 puma with a cable connected on the top and one coming from the bottom. Can anyone tell me what it is? Is it a fused link? Or some kind of bus bar connector? Also what is the part number? Could I connect one to the negative terminal? I need to connect the winch, the Anderson plug and a small fuse board.
Lee
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #185799 17th Nov 2012 1:02pm
Lee,
give Tim @mobilecentre a call, he's you man for all thing leccy !
Post #185802 17th Nov 2012 1:05pm
Could you not use the threaded hole on the opposite side. I put an extra bolt into it on mine but not had a use for it as of yet. Providing the wiring you are putting in isn't gigantic then it should be okay to add to what you've already got there. I have my spot light feed and amp on that very connection and the Amp power feed cable is 4 gauge 80A or something like that. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #185805 17th Nov 2012 1:16pm
mobilecentre
It is a bus bar type extension
Post #185818 17th Nov 2012 2:22pm
