![]() | Home > Technical > Electrical lighting fault - any ideas? |
Usual culprit is the headlamp switch itself, the Mickey Mouse contacts often melt. Steve.
DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 269 ![]() ![]() ![]() |
Thanks Steve. Is it something that can be tackled on a dark night with a head torch?
Have you got a soldering iron? 45 minutes to sort approximately.
![]() http://www.defender2.net/forum/topic5649.html?highlight=burnt http://www.defender2.net/forum/topic11186.html?highlight=solder If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
