Home > Technical > Electrical lighting fault - any ideas?
DC101
United Kingdom 2005 Defender 110 Td5 CSW Zambezi Silver
Hi,
I'm going away this weekend and last night had the following lighting fault on my 2003 td5.
Side lights on, all lights working including dash lights;
Dipped beam, no lights at all, including no dash lights.
Indicators still work in both cases. Can flash main beam in both cases.
Do you helpful folk have any suggestions or is it auto electrician time? Obviously needs fixing before Weekend...
Thanks in advance,
Robin
Post #184654 13th Nov 2012 2:30pm
Happyoldgit
Usual culprit is the headlamp switch itself, the Mickey Mouse contacts often melt. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #184657 13th Nov 2012 2:57pm
DC101
Thanks Steve. Is it something that can be tackled on a dark night with a head torch?
Post #184793 13th Nov 2012 8:58pm
K9F
Have you got a soldering iron? 45 minutes to sort approximately. Thumbs Up
http://www.defender2.net/forum/topic5649.html?highlight=burnt
http://www.defender2.net/forum/topic11186.html?highlight=solder
67_6Cyl wrote:
Thanks guys.
Switch out, blob of solder on, and back in, in less than 45 minutes including procrastination and making a steering wheel puller.
It was only the rivet/pin for the main beam that had melted and sunk into the PVC. Judicious application of heat from the back, pin pushed back into place, and a blob of solder to hold it onto the brass plate that connects the three outermost pins.
Now I have working lights again.
Once again, tanks for the quick and accurate diagnosis.
Jon
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #184839 13th Nov 2012 9:57pm
