![]() | Home > Maintenance & Modifications > Which cubby box replacement. |
| Thud Member Since: 21 Jul 2012 Location: London Posts: 667
Want to replace mine with one that is higher for a better armrest, bigger for more stuff and lockable. Is there a make which stands out above the rest?
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
We offer our fcxRADIOBOX which is on Special offer to forum members at the moment.
We can also cover the lid in our leather and add as much padding as you want. Click image to enlarge If the radio section is not required and you can wait a couple of weeks, we are about to launch our standard cubby box that has exactly the same shape / profile but comes without the opening radio section. Lastly, in the New Year we will have our fcxRadioSwitchbox with an additional switch panel available ... www.FCX.ME.uk Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
| JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412
I've always been very pleased with the ones from Mobile Storage and wouldn't hesitate to recommend them.
In the current 110 I've retained the original but fitted a lockable safe under it. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Can't be arsed with all that. I'm a prop maker by trade and I like to leave all the work behind when I can I'm ashamed to say.
| Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177
Now that's not bad at all Tim!
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21028
Awesome. Similar to what I did. ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Mine:
Click image to enlarge I didn't retain the cup holders on mine because I never used them. All I need now is a seal between the cubby and the lid and two types of clamp each side to hold it down secure so it's air tight for the sub. Inside it's all black carpeted. Basically though you would put anything into the front face of it you wanted. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
Thud, consider carefully what you want from that space between the seats.
Lots of possibilities out there, just be careful that any box you buy is compatible with the Puma. Some are too long especially with the drink holder and can interfere with the hi low gear lever. A lot of these boxes require drilling the panel underneath. Only one company I am aware of does a fixture so no drilling is required. Ditto only one company does two height of pads, so try and work out the height you require for the pad. Nakatanenga does a under cubby box security box. One of our customers uses this security box to transport legal class A drugs for medical purposes. GMB does a similiar box but for putting lots of electric bits in and has a twin voltage display if running two batteries. So decide exactly what you want, height, ease of fitting, drinks holder etc etc. Then decide what is best suited to your needs. Both MSS and Safari Equip do good cubby boxes and there will be other makers out there as well. Brendan |
| strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1404
I always thought your avatar was a cooking ring! Now I know different........ |
You probably could boil a pan of water on that thing.
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
I can just see that lot filling up with mud, bits of hay, straw, dog hair and bird feathers in mine Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Will Brendan turn up at your house, Thud, with a box for you to try insitu ?
We will ! |
