Home > Off Topic > what's it called ?
what's it called ?
i need a 60mm hose connector that can be bolted to a panel/bulkhead, I've been looking on the bay but not abolsutely sure what it's called... I tried "60mm hose connector flange" ...
60mm pipe
bulkhead->
Post #180153 29th Oct 2012 7:48pm
ickle
bulkhead connector??
Post #180155 29th Oct 2012 7:51pm
bob neville
60mm bulkhead flange.
http://www.ebay.co.uk/itm/PLASTIC-BULKHEAD...4aa48340af
You will need to know the ID of your pipe NOT the od Thumbs Up
2013 Defender 90 CSW - sold
Post #180170 29th Oct 2012 8:24pm
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
Steve,
Search (Eberspacher 60mm) I have just ordered all of my vents and pipes
This could work for you if it's to connect through the box.
http://www.ebay.co.uk/itm/60mm-air-ducting...amp;_uhb=1
Jason.
Post #180181 29th Oct 2012 8:51pm
Bob / Jason
Like one of those but with a flange so that it can be bolted to a bulkhead
Post #180182 29th Oct 2012 8:54pm
jasong4110
If you fitted from the outside the collar would lock against the bulkhead then on the inside fit the hose against the bulkhead and fasten with a jubilee clip this will hold the bracket against the box and lock it in place the same as a screw thread.
Jason.
Post #180183 29th Oct 2012 8:57pm
that would do the job, thanks Thumbs Up
Post #180186 29th Oct 2012 9:16pm
