![]() | Home > Off Topic > what's it called ? |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1863 ![]() ![]() ![]() |
bulkhead connector??
60mm bulkhead flange.
http://www.ebay.co.uk/itm/PLASTIC-BULKHEAD...4aa48340af You will need to know the ID of your pipe NOT the od ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
jasong4110 Member Since: 19 Oct 2009 Location: Henley On Thames Posts: 268 ![]() ![]() ![]() |
Steve,
Search (Eberspacher 60mm) I have just ordered all of my vents and pipes This could work for you if it's to connect through the box. http://www.ebay.co.uk/itm/60mm-air-ducting...amp;_uhb=1 Jason. |
Bob / Jason
Like one of those but with a flange so that it can be bolted to a bulkhead |
If you fitted from the outside the collar would lock against the bulkhead then on the inside fit the hose against the bulkhead and fasten with a jubilee clip this will hold the bracket against the box and lock it in place the same as a screw thread.
Jason. |
that would do the job, thanks
