![]() | Home > Maintenance & Modifications > Jacking and Axle Stands |
| MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682
This may seem like a noddy question...
I'm about to change the front shocks on my Puma 110, so I want to support the chassis on axle stands. I have checked the manual but can't really find what I need. Can you put tha axle stands under almost any of the chassis main components? I was thinking of just behind the front bumper so they're really easy to get at. I assume this is OK, as I know many use a pillar jack here as well? Thanks for any advice... |
| noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196
I usually put them just in front of the baulkhead outriggers, means you can roll in and out easily and not banging your head on them. If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
Thanks chaps, I do have a decent trolley jack and 2 x 3 ton axle stands...
I am careful about squishing my head! I think I found the answer on our own site: Click image to enlarge Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
| sense of adventure Member Since: 11 Nov 2011 Location: warwickshire Posts: 147
You don't need to jack the vehicle at all to change any of the shocks on a defender.
Thanks, I had read that elsewhere...but the LR Workshop Manual says:
I'll do some more research... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
[quote="MartinK"]
Thanks, I had read that elsewhere...but the LR Workshop Manual says: [quote]1. Loosen road wheel retaining nuts. 2. Support chassis on stands and remove road wheel. 3. Support axle weight with jack. 4. Remove shock absorber lower fixing and withdraw cupwasher, rubber bush and seating washer. 5. Remove four shock absorber bracket fixings. 6. Withdraw shock absorber and bracket assembly. 7. Withdraw lower seating washer, rubber bush and cupwasher. 8. Remove fixings, shock absorber to mounting bracket. 9. Withdraw mounting bracket. 10. Lift off top seating washer, rubber bush and cupwasher.[/ Ignore that, they always miss the bits about using the wire brush to remove debris and rust from the threads etc. A five minute phone call will have you sorted, and set up to do all the shockers in 15-20mins a corner. Call anytime on 07714419998 and I will explain Regards Will |
Great, Thanks! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
