Home > Maintenance & Modifications > Jacking and Axle Stands
MartinK
This may seem like a noddy question...
I'm about to change the front shocks on my Puma 110, so I want to support the chassis on axle stands.
I have checked the manual but can't really find what I need.
Can you put tha axle stands under almost any of the chassis main components? I was thinking of just behind the front bumper so they're really easy to get at.
I assume this is OK, as I know many use a pillar jack here as well?
Thanks for any advice... Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #180065 29th Oct 2012 1:31pm
noworries4x4
I usually put them just in front of the baulkhead outriggers, means you can roll in and out easily and not banging your head on them. If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #180074 29th Oct 2012 2:36pm
leeds
Get a good quality bottle jack or trolley jack.
Have tried the 2 tonne trolley jacks from the big tool sheds and was not impressed. They had a small saddle and tend to sink under load of a Defender.
Got a 3 tonne German trolley jack from Difflock and it has a 6" saddle and is Thumbs Up
Get good quality 3 tonne axle stands as well Thumbs Up
Safety comes first! How much is your head worth???
Brendan
Post #180078 29th Oct 2012 2:46pm
MartinK
Thanks chaps, I do have a decent trolley jack and 2 x 3 ton axle stands...
I am careful about squishing my head!
I think I found the answer on our own site:
Post #180097 29th Oct 2012 4:02pm
sense of adventure
United Kingdom 2010 Defender 110 Puma 2.4 USW Galway Green
You don't need to jack the vehicle at all to change any of the shocks on a defender.
Post #180101 29th Oct 2012 4:14pm
MartinK
Thanks, I had read that elsewhere...but the LR Workshop Manual says:
Quote:
1. Loosen road wheel retaining nuts.
2. Support chassis on stands and remove road wheel.
3. Support axle weight with jack.
4. Remove shock absorber lower fixing and withdraw cupwasher, rubber bush and seating washer.
5. Remove four shock absorber bracket fixings.
6. Withdraw shock absorber and bracket assembly.
7. Withdraw lower seating washer, rubber bush and cupwasher.
8. Remove fixings, shock absorber to mounting bracket.
9. Withdraw mounting bracket.
10. Lift off top seating washer, rubber bush and cupwasher.
I'll do some more research... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #180102 29th Oct 2012 4:26pm
sense of adventure
[quote="MartinK"]
[quote]1. Loosen road wheel retaining nuts.
10. Lift off top seating washer, rubber bush and cupwasher.[/
Ignore that, they always miss the bits about using the wire brush to remove debris and rust from the threads etc.
A five minute phone call will have you sorted, and set up to do all the shockers in 15-20mins a corner.
Call anytime on 07714419998 and I will explain
Regards
Will
Post #180156 29th Oct 2012 7:56pm
MartinK
Great, Thanks! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #180161 29th Oct 2012 8:10pm
