Home > Maintenance & Modifications > Shot Blasting and Power Coating
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
Hi Chaps,
I am just about to take delivery of my ARB bumper it needs blasting and power coating, does anyone know anywhere I can get this done around the M4/M40 corridor, Reading as the center?
Cheers, Jason.
Post #179916 28th Oct 2012 10:26pm
T1G UP
take it round and get a quote as removig old powdercoats hard going.
Post #179930 28th Oct 2012 10:36pm
Porny
Site Sponsor
If the old powdercoat is still holding on well... I tend to get stuff chemically dipped before hand.
Works out a lot cheaper, and makes life a lot easier for the powder coaters. Other option is to burn it off.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #179989 29th Oct 2012 8:30am
My old BRB bar was plastic (not the thinner powder) coated.... a friend tried blasting it and it wouldn't touch it.
He suggested getting an oxy torch, and just going over all of the coating and lightly scorching it.... just enough to make it start blistering and going a bit brown/black and crusty when it's cooled. It really didn't take long, maybe 15 minutes to do the whole bar.
Took it back and the stuff came straight off with the blaster. I got it re-plastic coated at the nudgebar center in Cirencester, they added it to one of their shipments to the coaters, a bit costly though, was about £60 I think, maybe slightly more, but it gave a much better coating than powder. certainly more "heavy duty" than the thinner powder,
Post #179994 29th Oct 2012 8:38am
Jason, I know a place in Trowbridge, AZ something, I'll look it up and PM you the details
Post #179995 29th Oct 2012 8:45am
jasong4110
I would Marcus but it's fairly big and heavy, I have some photos from Tim so have sent these off for a price, so far I have one reply. If it is powder coat then it will be £48 to have it blasted and a further £48 to have it re-coated. If it is the plastic stuff he recommends putting it in a fire to burn the stuff off.
Porny wrote:
If the old powdercoat is still holding on well... I tend to get stuff chemically dipped before hand. Works out a lot cheaper, and makes life a lot easier for the powder coaters. Other option is to burn it off.
Ian
The bumper is in good shape but the coating has seen better days, judging by the photos Tim sent me so it's going to be a case of having it blasted.
As above Jamie the chap has said to just stick it on a fire, I guess with bonfire night coming up then it may give me the chance of finding a large enough one!! Very Happy
That does not sound too much Jamie, although I have never been that impressed with the plastic coated stuff as I find it rusts underneath the coating if it gets damaged, has yours held up?
Cheers Steve,
Post #180003 29th Oct 2012 9:20am
Hi Jason,
I recently had various bits and pieces including some tubular side steps that I'd had galvanised, coated by this company in Windsor: www.swallowsprays.co.uk.
Not particularly cheap, but the quality seems good. Darren
Post #180013 29th Oct 2012 10:13am
McS
Procoat just outside Newbury, superb service and the finish is extremely durable!
http://www.professionalcoatings.co.uk/
Speak to Aston.
Ross The Scotia Winch Challenge
Post #180096 29th Oct 2012 4:01pm
Be careful chucking the whole thing onto a fire.... that could be too much heat and distort it (especially the tubes)
I'd be more inclined to use an oxy torch and do a bit at a time.
Post #180104 29th Oct 2012 4:33pm
jasong4110
LandRoverAnorak wrote:
Hi Jason,
Thanks Darren, I found them on my search yesterday and sent them an email but they have yet to get back to me I may have to chase later in the week.
Speak to Aston. Ross
Thanks Ross, I also sent them an email last night but have yet to hear anything from them yet, again I will chase them later in the week.
I had thought about that Jamie, it has arrived at Neil's so just need to pick it up first and then see where I am with it.
Thanks for the response, Jason.
Post #180149 29th Oct 2012 7:37pm
Busboy
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
I know of a good powder / blast guys in Cowley near Uxbrigde, they are two separate company's but based next door to each other on the same estate ......
I have got no contact details, but if you want to meet up early evening 1630ish, i can take you there on my way home Thumbs Up
PM me if needed
Steve Steve
Post #180171 29th Oct 2012 8:26pm
jasong4110
PM me if needed
Steve
Cheers Steve, I will let you know how I get on.
Jason.
Post #180173 29th Oct 2012 8:28pm
Chocolate
United Kingdom 2004 Defender 110 Td5 XS CSW Bonatti Grey
Hi Jason,
I used Slough Powder coatings for my bumperetts, they burnt of the plastic coating. Very good finish.
They have a huge oven there as well. Very Happy
http://www.sloughpowdercoating.co.uk
They do loads of satellite equipment and run 24 hours.
Wayne 110XS CSW TD5.
Post #180364 30th Oct 2012 2:15pm
Romadog
Theres a sand blaster in reading just off the road which runs parallel with M4 before the Foster Wheeler building. He did a Range Rover Tailgate for me.
R D Cox & Son
0118 975 0289
The Workshop, 306 Old Whitley Wood Lane, READING, RG2 8QD
Also
A & C Shotblasting
01635 523 775
Raceview Business Centre, Hambridge Road, NEWBURY, RG14 5SA
Did my 110 chassis before I had it galvanised in Southampton
Post #180436 30th Oct 2012 6:45pm
Blimey, that's a blast from the past! I used R D Cox to clean up a NATO hitch nearly 20 years ago Shocked Darren
Post #180487 30th Oct 2012 9:25pm
