Home > Puma (Tdci) > Gearbox issues??
Page 2 of 2 <12
dgardel
Italy
Re: Gearbox issues??
Constantin_Valdor wrote:
when I press the clutch the revs remain elevated for a while and then drop very very slowly.
Pressure clutch switch (located on the clutch pump, engine bay) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #178827 25th Oct 2012 8:49am
Happyoldgit
Which is pretty much what I said earlier in this thread Whistle Steve.
http://forums.lr4x4.com
Post #178881 25th Oct 2012 1:39pm
ZeDefender
2 votes for the clutch switch then Thumbs Up Tell someone you love them today because life is short.
Post #178893 25th Oct 2012 2:09pm
dgardel
Italy
Embarassed Embarassed Embarassed Embarassed
IID Pro MV License
Post #178908 25th Oct 2012 3:47pm
Jackh
South Africa 2010 Defender 110 Puma 2.4 CSW Alpine White
Hi- had same problem with my puma - engine accelerated when depressing clutch - after long search discovered it was faulty fuse 13 - rear brake lights. changed fuse and problem solved. regards jackh
disco 1 - 450,000km retired
puma 2010
Post #179784 28th Oct 2012 5:17pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
mine did the rising rev bit. if i recall it was a fuel pressure switch somewhere. the dealer fixed it and never had a problem since then.
don't worry about your new Defender just report the faults and if you have a good dealer they will fix them, i have always had excellent service from my dealer, thankfully.
re the clonk i reported a similar issue at my first service as it was not there when i bought it [at 5 months old] but was getting worse. it was just the nuts on the prop/brake drum a tad loose. again no probs since they were tightened. BM52
Post #179808 28th Oct 2012 6:15pm
Page 2 of 2 <12
