![]() | Home > For Sale & Wanted > Wanted: Td5 defender PAS pipes |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8381 ![]() ![]() ![]() |
i have some pipes (new) kicking about, do you know MPN i will cross check with what i have. Cheers
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6209 ![]() ![]() ![]() |
Cheers James, I'll get the numbers.
Pipe, reservoir to pump: QEH102570
Pipe, pump to steering box: QEP105122 ![]() ![]() |
Will take a gander tomorrow and let you know Cheers
Much apprciated.
not good, all the ones i have are not what you are after unless there is a cross ref to them. they are all tdi from res to pump and res to box. Sorry Cheers
Ah well, no worries.
Still after these.
also after the rubber heater pipes that go from the engine to the heater, and to the header tank and fuel cooler for early Td5 defender Anyone? |
OK, so i've got the pipes sorted, but it turns out that I've got a disco PAS pump on the engine I've fitted, so I need either a knackered DEFENDER PAS pump, or this union from one (The bit with the red plastic plug in
![]() ![]() Click image to enlarge It just unscrews from the pump (think it's 24 or 22mm OD) This union is smaller on a discovery pump: The OD of the WRONG disco threaded end on the pipe is 15.7mm (across the top of the threads) ID of the wrong union for the above is 14.4mm The correct defender union on the pipe, OD is 19.9mm, so I'd assume (without stripping my 110 pump off) that the ID of the union would be something like 18.6mm Anyone got an old pump they'd be willing to remove this union and sell/swap for a disco one??? |
