Home > For Sale & Wanted > Wanted: Td5 defender PAS pipes
I'm after the two high pressure pipes to and from the pump (one goes to the steering box, the other to the reservoir) for a Td5 defender.
Anyone?
Oh, and a pair of defender sunvisors. Thumbs Up
Post #173596 6th Oct 2012 6:09pm
jst
i have some pipes (new) kicking about, do you know MPN i will cross check with what i have. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #173927 8th Oct 2012 6:51am
Cheers James, I'll get the numbers. Thumbs Up
Post #173929 8th Oct 2012 7:13am
Pipe, reservoir to pump: QEH102570
Pipe, pump to steering box: QEP105122
Bow down Bow down
Post #173938 8th Oct 2012 7:51am
jst
Will take a gander tomorrow and let you know Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #174190 8th Oct 2012 8:57pm
Much apprciated.
Post #174250 9th Oct 2012 7:45am
jst
not good, all the ones i have are not what you are after unless there is a cross ref to them. they are all tdi from res to pump and res to box. Sorry Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #174263 9th Oct 2012 9:09am
Ah well, no worries.
Post #174278 9th Oct 2012 10:48am
Also after Td5 heater pipes
Still after these.
also after the rubber heater pipes that go from the engine to the heater, and to the header tank and fuel cooler for early Td5 defender
Anyone?
Post #175955 15th Oct 2012 3:33pm
Just a knackered PAS pump needed now....
OK, so i've got the pipes sorted, but it turns out that I've got a disco PAS pump on the engine I've fitted, so I need either a knackered DEFENDER PAS pump, or this union from one (The bit with the red plastic plug in Wink ):
It just unscrews from the pump (think it's 24 or 22mm OD)
This union is smaller on a discovery pump: The OD of the WRONG disco threaded end on the pipe is 15.7mm (across the top of the threads)
ID of the wrong union for the above is 14.4mm
The correct defender union on the pipe, OD is 19.9mm, so I'd assume (without stripping my 110 pump off) that the ID of the union would be something like 18.6mm
Anyone got an old pump they'd be willing to remove this union and sell/swap for a disco one???
Post #178678 24th Oct 2012 6:29pm
