Home > Maintenance & Modifications > Galvanizing steel hinges?
MPN
Finland 2003 Defender 110 Td5 USW Belize Green
As these are not the norm today, is there a problem in doing this?
In perfect world one would just have the hinges hot dipped and be done with it.
Why is this not done? Pin being the issue?
I'm sorry if this has been asked before, I tried to seach but pulled a blank.
Post #172744 2nd Oct 2012 7:32pm
No reason why you couldn't..... knock the pin out (it's just on splines), get them dipped and knock the pin back in (with the plastic washer things)
Post #172747 2nd Oct 2012 7:42pm
MPN
Really?
Will be dropping a pair of body cappings in anyway.
I'd much prefer this route to aluminium/SS hinges,
Cool! Very Happy
Thanks Jim!
Post #172753 2nd Oct 2012 7:55pm
leeds
Is there enough clearance for the pins after hot dipping galv? What about galv 'snots'?
The holes might need drilling or reaming out after dipping??
Brendan
Post #172764 2nd Oct 2012 8:07pm
drive4change
United Kingdom 1993 Defender 130 200 Tdi HCPU Alpine White
Brendan is definitely right pointing out that you would almost certainly have to redrill the hole for the pin after galvanising. I shouldn't think there would be a clearance issue as the holes for the bulkhead flap pins are very tight and many people refit these after galvanising the bulkhead. Thumbs Up
Let us know how you get on. May well galvanise our hinges Thumbs Up
Post #172817 2nd Oct 2012 9:53pm
MPN
This will be a cheap experiment to do after all.
I think I'll give it a try.
I have been quoted a fixed sum up to 100kgs for the dip, and my cappings weigh less than 15kgs.
So, the dip is basically free for all the extra bits.
Post #172856 3rd Oct 2012 6:34am
If you work out how thick the zinc layer is, you could drill out the holes prior to getting them dipped, then they'll just fit straight in afterwards.
Post #172869 3rd Oct 2012 7:52am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
My experience of galving parts that small is that may go missing and end up in the bottom of the tank. The shrug of shoulders from the galv company is little compensation.
Can cast metal be galved easily? Without changing the bath temperature and the immersion time it's going to be difficult to get right and many places won't want to change their processes for a small run.
Post #172872 3rd Oct 2012 8:00am
