![]() | Home > Maintenance & Modifications > Galvanizing steel hinges? |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6176 ![]() ![]() ![]() |
No reason why you couldn't..... knock the pin out (it's just on splines), get them dipped and knock the pin back in (with the plastic washer things)
MPN Member Since: 23 Sep 2012 Location: Tuusula Posts: 18 ![]() ![]() ![]() |
Really? Will be dropping a pair of body cappings in anyway. I'd much prefer this route to aluminium/SS hinges, Cool! ![]() Thanks Jim! |
Is there enough clearance for the pins after hot dipping galv? What about galv 'snots'?
The holes might need drilling or reaming out after dipping?? Brendan |
drive4change Member Since: 15 Aug 2012 Location: Somerset Posts: 193 ![]() ![]() ![]() |
Brendan is definitely right pointing out that you would almost certainly have to redrill the hole for the pin after galvanising. I shouldn't think there would be a clearance issue as the holes for the bulkhead flap pins are very tight and many people refit these after galvanising the bulkhead.
![]() Let us know how you get on. May well galvanise our hinges ![]() |
This will be a cheap experiment to do after all.
I think I'll give it a try. I have been quoted a fixed sum up to 100kgs for the dip, and my cappings weigh less than 15kgs. So, the dip is basically free for all the extra bits. |
If you work out how thick the zinc layer is, you could drill out the holes prior to getting them dipped, then they'll just fit straight in afterwards.
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
My experience of galving parts that small is that may go missing and end up in the bottom of the tank. The shrug of shoulders from the galv company is little compensation.
Can cast metal be galved easily? Without changing the bath temperature and the immersion time it's going to be difficult to get right and many places won't want to change their processes for a small run. |
