![]() | Home > Off Topic > Nitrogen in tyres |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4806 ![]() ![]() |
![]() ![]() ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Who would have thought a thread could go so terribly wrong - so tempted to quote that Wiki entry
![]() At least there are no images ![]() But shout it at them in German because life is also terrifying and confusing... |
Agree. One thing to keep in mind though. If you want to do this correctly, it also means that if you are checking your tire pressure later, and if you need to add some "air", you should go back to a tire fitter who has the nitrogen available, and add nitrogen there. So for those here who are deflating and inflating their tires regularly off-road, might not really work,.... unless they buy a bottle of nitrogen off course
![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
l ![]() |
To get any benefit your plans would need to be really short. No good for tomatoes! Or the environment, or your pocket! |
MarkyMT Member Since: 24 Sep 2012 Location: Sitting in Somerset Posts: 2 ![]() ![]() |
FWIW KwikFit & some ATS have nitrogen machines. KF's not too bad on price when they are running a 25% promotion on a set of 4 and in the past they've worked out cheaper than anyone else...especially on a set of Michellin's or Conti's.
Agreed about 'topping up with air, however needs must! Seems to be back on topic now! |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 655 ![]() ![]() ![]() |
Errrr, what's this about nitrogen getting less hot in a tyre than air? I don't see any way that can be true. Surely the vast majority of friction in a tyre is not within the gas itself, but as a result of the tyre rotating against the tarmac. On a big tyre like a Land Rover tyre, the amount of heat that can be stored in the casing and the belts is going to vastly exceed the amount that could be stored in the gas inside.
Not only that, but the specific gas constants (which determine how much something heats up when work is done on it) relating to air and nitrogen are only different by a tiny amount: 0.287kJ/kgK versus 0.297kJ/kgK. The test done with the Audi has one fatal flaw: it may be a Quattro but that doesn't mean your front and rear tyres are seeing equal amounts of work! Particularly where fancy all-wheel-drive systems are involved which may be transferring drive here there and everywhere. To come close to being scientific you'd have to inflate the left tyres with nitrogen and the rights with air, then do 0-100-0 runs down a dead straight road. I thought the reasons for nitrogen tyre inflation were a) its lack of moisture which prevents imbalance in aircraft tyres running at very low temps, and b) its larger molecules meaning it leaks more slowly. The latter may be true, but you should check your pressures regularly anyway, and if you do find they're flat, are you gonna drive to the tyre place to top up with nitrogen? No, so what's the point. Particularly on an off-roader where you might air your tyres up and down 3x in a day's driving. |
FYI...there are alot of Inert gases..i use one daily..Argon.
Thats the I in TIG. Tungsten Inert Gas ![]() |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Spot on. Nitrogen won't make the slightest differtence when it comes to temperature. Here is a better explanation from another site:
Basically if you have the ability to put nitrogen in then yes it is a good idea (or just put an air drier on your compressor).... but on a Land Rover I don't see the benefit. It isn't like you throw it around back roads at high speed to create huge amounts of heat. Nitrogen gets used in hgigh temperature aplications such as race cars, performance cars and aircraft. Glyn ![]() ![]() |
