Home > Off Topic > Nitrogen in tyres
Page 2 of 2 <12
spudfan
Ireland
Shocked ThinkI'll stick with being thick. Rolling with laughter
Thumbs Up 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #170124 23rd Sep 2012 10:28am
ZeDefender
Who would have thought a thread could go so terribly wrong - so tempted to quote that Wiki entry Laughing
At least there are no images Shocked Tell someone you love them today because life is short.
Post #170132 23rd Sep 2012 10:56am
MarkyMT
I've used nitrogen in my tyres for around 6yrs, yep it can be seen as a marketing gimmick but at only £1 a corner it's hardly a huge money earner.
Did a little test with my Audi A6 Quattro by filling my rears with air and fronts with nitrogen and courtesy of a TPMS (tyre pressure monitoring system) was able to assess
All tyres at 34psi
ambient temperature today 15 degrees
After a 100 mile dry drive fronts were both reading 35psi but rears were reading 39 & 40!
So a 3% fluctuation on nitrogen - granted there is some normal air in there...nowt you can do about that
A whopping 15% fluctuation on air Surprised
So surely based on this basic test your more likely to have over-inflated tyre wear with air, namely the centre of the wheel may wear more...certainly more than the 12% difference.
The best way to get it free is to barter for 'nitrogen all-round' when buying a new tyre...then they'll do it for free!
Mark
Post #170348 24th Sep 2012 12:17am
ericvv
Agree. One thing to keep in mind though. If you want to do this correctly, it also means that if you are checking your tire pressure later, and if you need to add some "air", you should go back to a tire fitter who has the nitrogen available, and add nitrogen there. So for those here who are deflating and inflating their tires regularly off-road, might not really work,.... unless they buy a bottle of nitrogen off course Whistle You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #170354 24th Sep 2012 5:08am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
l
Wink I can get you a picture if you like.
Post #170361 24th Sep 2012 7:16am
me@td5.org
ZeDefender wrote:
I find mixing CO2 and Sulphurhexafluride grows cracking veg in the old polytunnel Wink
To get any benefit your plans would need to be really short. No good for tomatoes! Or the environment, or your pocket!
Post #170362 24th Sep 2012 7:22am
MarkyMT
FWIW KwikFit & some ATS have nitrogen machines. KF's not too bad on price when they are running a 25% promotion on a set of 4 and in the past they've worked out cheaper than anyone else...especially on a set of Michellin's or Conti's.
Agreed about 'topping up with air, however needs must!
Seems to be back on topic now!
Post #170369 24th Sep 2012 8:28am
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Errrr, what's this about nitrogen getting less hot in a tyre than air? I don't see any way that can be true. Surely the vast majority of friction in a tyre is not within the gas itself, but as a result of the tyre rotating against the tarmac. On a big tyre like a Land Rover tyre, the amount of heat that can be stored in the casing and the belts is going to vastly exceed the amount that could be stored in the gas inside.
Not only that, but the specific gas constants (which determine how much something heats up when work is done on it) relating to air and nitrogen are only different by a tiny amount: 0.287kJ/kgK versus 0.297kJ/kgK.
The test done with the Audi has one fatal flaw: it may be a Quattro but that doesn't mean your front and rear tyres are seeing equal amounts of work! Particularly where fancy all-wheel-drive systems are involved which may be transferring drive here there and everywhere. To come close to being scientific you'd have to inflate the left tyres with nitrogen and the rights with air, then do 0-100-0 runs down a dead straight road.
I thought the reasons for nitrogen tyre inflation were a) its lack of moisture which prevents imbalance in aircraft tyres running at very low temps, and b) its larger molecules meaning it leaks more slowly. The latter may be true, but you should check your pressures regularly anyway, and if you do find they're flat, are you gonna drive to the tyre place to top up with nitrogen? No, so what's the point. Particularly on an off-roader where you might air your tyres up and down 3x in a day's driving.
Post #170370 24th Sep 2012 8:45am
T1G UP
FYI...there are alot of Inert gases..i use one daily..Argon.
Thats the I in TIG. Tungsten Inert Gas Thumbs Up
Post #170376 24th Sep 2012 10:39am
Glynparry25
Spot on. Nitrogen won't make the slightest differtence when it comes to temperature.
Here is a better explanation from another site:
Quote:
Fundamentally; air, oxygen and nitrogen will all behave exactly the same in terms of pressure change for each 10 degrees of temperature change. However temperature alone is not the whole story.
Ambient air contains moisture, nitrogen does not. If moisture is present it contributes to a greater change in pressure simply because at lower temperatures water condenses to become a liquid. The liquid form of water occupies very little volume and contributes only a negligible pressure to the tire. But at higher temperatures, such as those in a running tire, water evaporates inside the tire and becomes a gas which increases pressure in the tire.
Ambient air contains about 21% oxygen. Oxygen’s smaller molecular size allows it to permeate through the rubber of the tire. By inflating with nitrogen, which is much less permeable than oxygen, the pressure changes due to oxygen loss are greatly reduced.
The racing industry is correct; nitrogen is more predictable. Because nitrogen is dry it has no moisture to contribute extra pressure changes with temperature. Because nitrogen permeates out much slower than oxygen pressure changes due to that leakage are almost eliminated compared with ambient air.
Basically if you have the ability to put nitrogen in then yes it is a good idea (or just put an air drier on your compressor).... but on a Land Rover I don't see the benefit. It isn't like you throw it around back roads at high speed to create huge amounts of heat. Nitrogen gets used in hgigh temperature aplications such as race cars, performance cars and aircraft.
Glyn Dog Sheep
Post #170383 24th Sep 2012 11:03am
Page 2 of 2 <12
