![]() | Home > Maintenance & Modifications > Can you use SMXS in the Transfer box ? |
| Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 339
GL5 oils have a higher proportion of EP and anti-scuffing agents and are better suited to the higher point contact loads encountered in differentials and final drive units - so no, do not use GL4 oil in the transfer box.
In some cases you may be able to use a synthetic GL5 oil instead of GL4 but unless specifically recommended by Landrover or an oil manufacturer, I for one would certainly not use it in the Defender gearboxes. |
[Deleted double post - must remember not to use the browser 'back' button]
| rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297
Thanks Mr Horseman. I'll stick to the syntrax then.
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
Rossy, have a look at this. You won't have to spend much to get free delivery from Mick's Garage.Here is their recommendation for the Puma.
http://total-gbr.lubricantadvisor.com/advi...2f5afe4d02 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2510
In fact you can use GL-4 in the Tbox (not gl-3 though) as specs states it. Puma 110" SW
