Home > Maintenance & Modifications > Can you use SMXS in the Transfer box ?
rossy
The year is up and I'm going to change the Tbox oil. Last time I used Syntrax 75/90 GL4/5 ( and in the gearbox SMXS 75/90 GL3/4). I know their names have changed to universal and multivehicle or something like that.
There's not much difference in price between the two and because SMX is fully synthetic I was wondering if its OK for the transfer box or even better ?
The distinctions between the GL 3/4/5 types seem to be blurred these days as the good stuff has no bronze-damaging chlorine so would SMX in the Tbox be unecessary silliness or bad in some way?
Just wondered. Thanks
Post #169872 22nd Sep 2012 8:50am
Fifth Horseman
GL5 oils have a higher proportion of EP and anti-scuffing agents and are better suited to the higher point contact loads encountered in differentials and final drive units - so no, do not use GL4 oil in the transfer box.
In some cases you may be able to use a synthetic GL5 oil instead of GL4 but unless specifically recommended by Landrover or an oil manufacturer, I for one would certainly not use it in the Defender gearboxes.
Post #169883 22nd Sep 2012 9:12am
Fifth Horseman
[Deleted double post - must remember not to use the browser 'back' button]
Post #169884 22nd Sep 2012 9:12am
rossy
Thanks Mr Horseman. I'll stick to the syntrax then.
Post #169900 22nd Sep 2012 10:28am
spudfan
Ireland
Rossy, have a look at this. You won't have to spend much to get free delivery from Mick's Garage.Here is their recommendation for the Puma.
http://total-gbr.lubricantadvisor.com/advi...2f5afe4d02 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #169931 22nd Sep 2012 2:20pm
rossy
Thumbs Up
Post #169982 22nd Sep 2012 7:04pm
MK
In fact you can use GL-4 in the Tbox (not gl-3 though) as specs states it. Puma 110" SW
Post #170053 22nd Sep 2012 10:20pm
