![]() | Home > Off Topic > Loss of power |
fuel...
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 ![]() ![]() ![]() |
Diesel, sainsburys...... 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20951 ![]() ![]() |
Try Shell fuel or Esso or the like permanently and no supermarket fuel. IF you still get it happen at some point you can then rule that out as being an issue at the very least.
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
lack of it! sounds like it can't keep up with the supply a higher engine speeds. i guess its ok around town etc?
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196 ![]() ![]() |
Air flow meters can be a problem on the D4D engines, check for fault codes with an obd reader, those codes on jap systems rarely bring on the management light. I plugged in the reader on my wifes rav and there was over a page of faults not ever bringing the light on erased them all and the car now flies. If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
Thanks for your input chaps
![]() Beer 'n Sex 'n Chips 'n Gravy ![]() |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297 ![]() ![]() ![]() |
sounds identical to the problem I had with a Mitsubishi Outlander. It turned out to be a gunged up MAP sensor. This happened twice within a year and after 2 replacements I cured the problem by using 2 stroke oil in the diesel which must have kept everything clean
