Home > Off Topic > Loss of power
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
Loss of power
Sorry but its actually not a problem with my Defender, but the wife's Rav4. Just wondered if anyone could shed any light on this issue.
These are the symptoms .. driiving around fine, got onto the motorway and after about 10mins of doing about 70mph I had to decelerate so took my foot off the gas, then when I went to put my foot down again there would be no power and the car would very slowly loose some speed. Pulled into the services and down through the gearbox and then the car drives fine, back onto the motorway and no further issues. This has happened twice now?
My thoughts are, blocked fuel filter, dirty egr valve, faulty throttle sensor ??
Anyone?
cheers Dan 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #168993 17th Sep 2012 9:05pm
T1G UP
fuel...
Post #168994 17th Sep 2012 9:06pm
chiefstoker
Diesel, sainsburys...... 2005 TD5 90 Hard Top
Post #168997 17th Sep 2012 9:20pm
Try Shell fuel or Esso or the like permanently and no supermarket fuel. IF you still get it happen at some point you can then rule that out as being an issue at the very least. Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #169007 17th Sep 2012 9:54pm
T1G UP
lack of it! sounds like it can't keep up with the supply a higher engine speeds. i guess its ok around town etc?
Post #169009 17th Sep 2012 9:56pm
noworries4x4
Air flow meters can be a problem on the D4D engines, check for fault codes with an obd reader, those codes on jap systems rarely bring on the management light. I plugged in the reader on my wifes rav and there was over a page of faults not ever bringing the light on erased them all and the car now flies. If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #169024 17th Sep 2012 10:44pm
chiefstoker
Thanks for your input chaps Thumbs Up 2005 TD5 90 Hard Top
Post #169090 18th Sep 2012 6:08pm
rossy
sounds identical to the problem I had with a Mitsubishi Outlander. It turned out to be a gunged up MAP sensor. This happened twice within a year and after 2 replacements I cured the problem by using 2 stroke oil in the diesel which must have kept everything clean
Post #169148 18th Sep 2012 9:30pm
