Home > My Defender > im now part of the puma crew :D
Page 21 of 34 <123 ... 202122 ... 323334>
Killer90
Site Sponsor
custom90steve wrote:
Didn't waste time did you. Shocked
Thumbs Up
got to be done mate Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #197301 29th Dec 2012 8:03pm
Killer90
Site Sponsor
Well todays progress- wired in the sub/amp, drilled a 20mm hole in the rear bulkhead, used a genuine lr grommet and run the wires through. All i need to do now is fix down the fuse block behind the seat and tidy up the wires with some plastic sleeving and the stick on tie downs to keep the wires nice and tight and hidden. Thumbs Up
And heres a better photo of the alcantara and leather dash bits Thumbs Up
 CSK Automotive
Post #197304 29th Dec 2012 8:09pm
GUM97
Very nice Thumbs Up You finally got your little wiring problem sorted out then eh Very Happy An engine to TDi for!
Post #197307 29th Dec 2012 8:17pm
Neatly done mate. Thumbs Up Still say one day you should update your fuse & holder. Whistle ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #197313 29th Dec 2012 8:32pm
Killer90
Site Sponsor
Whistle Yer eventually all sorted, its so easy GUM when you work out whats what. there was atleast 10 wires coming out the back turns out you only need them ones i pocked through the bulkhead in the photo Rolling Eyes
Cheers Steve Thumbs Up thanks for all the help top advice mate. I was looking at some today actually but ill wait till this one goes boom Laughing hopefully never Thumbs Up CSK Automotive
Post #197346 29th Dec 2012 9:22pm
BigWheels
I'd have had the dash & passenger handle black stitched as white will soil. If the thread is teflon it might be OK for wiping clean... Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #197348 29th Dec 2012 9:25pm
Chris - It probably won't fail unless you try to kill it. And frankly you'll kill your hearing first probably instead. If you see any signs of melting though I certainly would then! And your welcome to the advice mate. Told you that you wouldn't need half of the wires. Laughing
Off Topic But how come you've not painted your own heater rings yet mate? ____\We|Will|Win/___
Post #197351 29th Dec 2012 9:25pm
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
The alcantara looks great. Good choice.
Post #197354 29th Dec 2012 9:30pm
Killer90
Site Sponsor
Steve they are painted mate just look silver in the photo Laughing , there gloss white with the carbon fibre style pattern on them Thumbs Up CSK Automotive
Post #197359 29th Dec 2012 9:44pm
Killer90
Site Sponsor
Thumbs Up Cheers Thud, i wanted something different that no one has so half and half i thought was good Mr. Green plus it matches the momo nero wheel Cool CSK Automotive
Post #197360 29th Dec 2012 9:45pm
Must be the angle then. Embarassed ____\We|Will|Win/___
Post #197363 29th Dec 2012 9:58pm
Killer90
Site Sponsor
yer its true when i painted the dash silver in the 110 someone thought it was white Laughing CSK Automotive
Post #197368 29th Dec 2012 10:06pm
Killer90 wrote:
Chris - In that photo above where did you earth it? Was it a seat bolt you said? Regardless you see the small bolts on that lip in the photo that was where I earthed mine and I checked that was a good earthing point as well.
(the bolt just below the yellow wire)
Might be easier if you earth it there on the bulkhead side so if you have to take seats out or anything you don't have to mess about with earth wires hanging around.
Thumbs Up ____\We|Will|Win/___
Post #197372 29th Dec 2012 10:12pm
Killer90
Site Sponsor
i did dit it to one of them bolts Steve but the one closest to the seat, i could have took the feed from that bolt, actually i dont know why i didnt Rolling Eyes still i might cut and recrimp and fix it there instead make the wire shorter but its not a big deal will all be hidden Thumbs Up CSK Automotive
Post #197384 29th Dec 2012 10:24pm
Ah I see. Don't worry then unless you wanted too. I thought you meant one of the bolts holding the seat frame. Laughing ____\We|Will|Win/___
Post #197389 29th Dec 2012 10:32pm
