![]() | Home > Technical > 11MY repeat fault codes |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8407 ![]() ![]() ![]() |
from: http://www.defender2.net/forum/topic13065.html how do you check the actuator control bar is moving freely? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Check that the control bar is loose at both ends and there is grease present on both ball joints. You can see in the below pics the modulator and vane arms with a bar connecting them together, this is the control bar/actuator rod.
![]() Click image to enlarge ![]() Click image to enlarge Brian. |
James, what tool are you using for the live data and the reading of the dtc's? Is the reading MAP psi or Boost psi on the gauge?
The reason I ask is that my Puma averages 225kPa which is 32-33 psi ![]() &feature=plcp Brian. |
scanguage. its set to boost. Cheers
Check the battery output capacity Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
battery output seems to be what i would expect. or do you mean something more specific.
have done another 100 miles, same faults showing as previous. with a reset part way through Just put the egr off map back on and now no faults showing after 20 miles. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
noise and lack of mpg is directly affected by which map i am running. egr off and no noise or normal economy. egr working and poor economy and noise under load. Cheers
mine makes some funny noises with the egr open. Still seeing 420 a tank ish so can't say the economys any different now my maps off. Had it checked over yet? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17954 ![]() ![]() ![]() |
Screeching when under boost would make me take a really close look at the pipes from trubo to intercooler, the intercooler itself and the pipe from the intercooler to the inlet manifold. A slit or split in one of the rubber pipe will cause exactly this sound. Temperature is also a factor since the pipes become more flexible when hot. |
these pipes are all good and checked. it only does it under heavy boost when running the egr open (ie std) file. Cheers
Tim seymour Member Since: 17 Jan 2010 Location: Devonport TAS Posts: 92 ![]() ![]() |
Hi sorry to but in i have a remap and my boost is about 21psi what is standard boost and i would like to know how to test the actuator arm do you have to disconnect arm from the control box ect cheers Tim ![]() |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 ![]() ![]() ![]() |
I get that with mine sometimes - mainly when towing the caravan but now and again just driving. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
that was my first thoughts approx 12mths ago, but it seems not to be the case. Cheers
