Home > Technical > 11MY repeat fault codes
Page 2 of 2 <12
jst
Lorryman100 wrote:
Feels more like a Boost issue to me and I would be checking the Turbo actuator control bar is moving freely and not binding. The electronic sensor for Boost is the MAP sensor mounted on the inlet manifold and if this is faulty you will lose active boost so it is worth giving it a clean as are the plug connections with an electrical contact cleaner.
from: http://www.defender2.net/forum/topic13065.html
how do you check the actuator control bar is moving freely? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #167321 10th Sep 2012 12:18pm
jst
just ran the vehicle again in std tune, working egr (or its meant to be) having cleared faults last time, its come up same again:
P068A - Engine Control Module/powertrain control module - power realy de-energised too early
P0606 - Engine Control Module/powertrain control module processor
P0404 - EGR control - circuit range performance
P0100 - Mass or volume air flow circuit
P1402 - EGR - metering orifice restricted/valve position sensor circuit
P0299 - turbo underboost
i am seeing what i think is full std boost pressure - 18psi under heavy load. how long it takes to get there compared to what it should be i dont know.
my thoughts are either sticky EGR valve allowing air to escape as i would assume actuator on turbo is working as i reach full pressure.
or a mate suggested an issue with turbo bearings - hence the squealing noise too. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #167438 10th Sep 2012 6:29pm
Lorryman100
Check that the control bar is loose at both ends and there is grease present on both ball joints. You can see in the below pics the modulator and vane arms with a bar connecting them together, this is the control bar/actuator rod.
Brian.
Post #167445 10th Sep 2012 6:39pm
Lorryman100
James, what tool are you using for the live data and the reading of the dtc's? Is the reading MAP psi or Boost psi on the gauge?
The reason I ask is that my Puma averages 225kPa which is 32-33 psi Confused
&feature=plcp
Brian.
Post #167451 10th Sep 2012 6:51pm
jst
scanguage. its set to boost. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #167491 10th Sep 2012 9:11pm
dgardel
Italy
Check the battery output capacity Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #167553 11th Sep 2012 9:25am
jst
battery output seems to be what i would expect. or do you mean something more specific.
have done another 100 miles, same faults showing as previous. with a reset part way through
Just put the egr off map back on and now no faults showing after 20 miles. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #167606 11th Sep 2012 2:49pm
jst
noise and lack of mpg is directly affected by which map i am running. egr off and no noise or normal economy. egr working and poor economy and noise under load. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #170904 26th Sep 2012 6:55am
T1G UP
mine makes some funny noises with the egr open. Still seeing 420 a tank ish so can't say the economys any different now my maps off.
Had it checked over yet?
Post #170922 26th Sep 2012 8:55am
jst wrote:
Lorryman100 wrote:
Symptoms where a high pitched squeal like a mild slipping fan belt. Sounded the same as when an exhaust manifold stud had snapped on a 200TDI. The noise only appeared once the engine was warm and the squealing coincided with boost demand.
Hi Brian
sounds exactly like that ^^^^^ and only when under boost.
BUT its only come about since removing the egr blank software.
i guess that would explain P0299, P0100???
Screeching when under boost would make me take a really close look at the pipes from trubo to intercooler, the intercooler itself and the pipe from the intercooler to the inlet manifold. A slit or split in one of the rubber pipe will cause exactly this sound.
Temperature is also a factor since the pipes become more flexible when hot.
Post #170924 26th Sep 2012 9:05am
jst
these pipes are all good and checked. it only does it under heavy boost when running the egr open (ie std) file. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #171025 26th Sep 2012 4:53pm
Tim seymour
Australia
&feature=plcp
Bran.
Hi sorry to but in i have a remap and my boost is about 21psi what is standard boost and i would like to know how to test the actuator arm do you have to disconnect arm from the control box ect cheers Tim Razz Cess the Taswegian
Post #172621 2nd Oct 2012 2:43am
JSG
Lorryman100 wrote:
Could the noise you are hearing be the viscous fan running?
Brian.
I get that with mine sometimes - mainly when towing the caravan but now and again just driving. John
2011 Tdci 110 CSW XS
Post #172934 3rd Oct 2012 1:05pm
jst
that was my first thoughts approx 12mths ago, but it seems not to be the case. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #172947 3rd Oct 2012 1:20pm
Page 2 of 2 <12
