![]() | Home > Off Topic > NPT connectors |
Does anybody know where I can purchase a 1/8 27 NPT female to 1/16 npt male reducer from ?
Google is not my friend unless I want to buy from the US or buy 100 at a time ![]() Thanks Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
B&Q etc will sort you out ?
Glyn ![]() ![]() |
Nope
![]() The best places I can find are air line or hydraulic suppliers but most of the connectors are BSP or NTP to BSP. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Fleabay - US or Australia !
Machine shop sounds like a good idea. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18028 ![]() ![]() ![]() |
I was trying to get something vaguely similar but even more specialised not long ago (3/8 NPTF male to 3/8 NPS male, working pressure 700bar) and it proved well-nigh impossible. In the end I made one. It is of course reasonable to expect an NPTF fitting to be even harder to find than an NPT.
Have you tried visiting your local hydraulic/specialist hose dealer ? You may have more success going for a 1/8 NPT to 1/16 NPT male to male nipple with a 1/8 NPT to 1/8 NPT female to female adaptor. Hyphose Ltd in Poole (and I think other south coast locations) might be worth a try, depending on your location, since they had a good range of NPT fittings when I was looking for mine (it was the NPS thread which had them stumped, not the NPTF). It is rare that they let me down. |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Try Best Fittings
They are mainly for the air gun market but may well be able to help you out if a local hydraulic supplier can't help as already suggested. DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
Thanks BW/DJ I will give those a try.
My local hydraulic supplier closed down otherwise I would have gone to them. Suppose I could nip down to Augusta/Westlands ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 655 ![]() ![]() ![]() |
This is probably stating the bleeding obvious, but you know that NPT is an American standard, right?
Thus I'd hope AgustaWestlands, being European, would be using proper ISO/BSP hydraulic fittings. Anyway.... |
Sure do
![]() You would be amazed at the different spec fittings on a Lynx ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
fixit Member Since: 15 Mar 2012 Location: Sunny devon Posts: 66 ![]() |
It will be worth a check but im petty sure bsp and npt are near enough the same to be unterchangable below 3/8"
They are not the same as the thead angle is different i think from memory 55bsp or 60npt degrees What is the intended use if it is a high pressure or critical fitting there is only the right way forward Larger sizes are deff not compatable http://www.turbominis.co.uk/forums/index.php?p=vt&tid=4208 |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196 ![]() ![]() |
Pirtek Hydraulics you will find one near you definatly got one on Marsh Barton in Exeter if they don't stock it they will find it for you. If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
Thanks all, now sorted
![]() Pirtek Marsh Barton had exactly what I needed. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
