Home > Off Topic > NPT connectors
bob neville
NPT connectors
Does anybody know where I can purchase a 1/8 27 NPT female to 1/16 npt male reducer from ?
Google is not my friend unless I want to buy from the US or buy 100 at a time Shocked
Thanks
2013 Defender 90 CSW - sold
Post #164104 24th Aug 2012 8:56am
Glynparry25
B&Q etc will sort you out ?
Glyn Dog Sheep
Post #164106 24th Aug 2012 9:15am
bob neville
Nope Big Cry
The best places I can find are air line or hydraulic suppliers but most of the connectors are BSP or NTP to BSP.
Post #164107 24th Aug 2012 9:22am
Glynparry25
2 other shots-
feabay?- you can get ANYTHING there (I can't check it on work computer though Sad )
or
Probably easiest and not very expensive will be to ask a machining shop to make it up on a lathe- once the computer knows what it is doing you will have the product in 5-10 mins.
Glyn Dog Sheep
Post #164109 24th Aug 2012 9:27am
bob neville
Fleabay - US or Australia !
Machine shop sounds like a good idea.
Post #164113 24th Aug 2012 9:38am
I was trying to get something vaguely similar but even more specialised not long ago (3/8 NPTF male to 3/8 NPS male, working pressure 700bar) and it proved well-nigh impossible. In the end I made one. It is of course reasonable to expect an NPTF fitting to be even harder to find than an NPT.
Have you tried visiting your local hydraulic/specialist hose dealer ? You may have more success going for a 1/8 NPT to 1/16 NPT male to male nipple with a 1/8 NPT to 1/8 NPT female to female adaptor. Hyphose Ltd in Poole (and I think other south coast locations) might be worth a try, depending on your location, since they had a good range of NPT fittings when I was looking for mine (it was the NPS thread which had them stumped, not the NPTF). It is rare that they let me down.
Post #164121 24th Aug 2012 10:19am
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Try Best Fittings
They are mainly for the air gun market but may well be able to help you out if a local hydraulic supplier can't help as already suggested.
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #164123 24th Aug 2012 10:53am
bob neville
Thanks BW/DJ I will give those a try.
My local hydraulic supplier closed down otherwise I would have gone to them.
Suppose I could nip down to Augusta/Westlands Whistle
Post #164126 24th Aug 2012 11:09am
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
This is probably stating the bleeding obvious, but you know that NPT is an American standard, right?
Thus I'd hope AgustaWestlands, being European, would be using proper ISO/BSP hydraulic fittings.
Anyway....
Post #164129 24th Aug 2012 11:23am
bob neville
Sure do Thumbs Up
You would be amazed at the different spec fittings on a Lynx Shocked
Post #164132 24th Aug 2012 11:40am
fixit
It will be worth a check but im petty sure bsp and npt are near enough the same to be unterchangable below 3/8"
They are not the same as the thead angle is different i think from memory 55bsp or 60npt degrees
What is the intended use if it is a high pressure or critical fitting there is only the right way forward
Larger sizes are deff not compatable
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=4208
Post #165024 29th Aug 2012 12:29am
noworries4x4
Pirtek Hydraulics you will find one near you definatly got one on Marsh Barton in Exeter if they don't stock it they will find it for you. If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #165059 29th Aug 2012 10:37am
bob neville
Thanks all, now sorted Thumbs Up
Pirtek Marsh Barton had exactly what I needed.
Post #165070 29th Aug 2012 11:27am
