Home > Technical > Speedo changing with bigger tyres
Page 2 of 2 <12
boode
England 2003 Defender 90 Td5 HT Rutland Red
Thanks for all the help
Post #164124 24th Aug 2012 11:05am
dgardel
Italy
You can use a Nanocom also Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #164138 24th Aug 2012 1:01pm
Froogle-Yorkshireman
2010 Defender 110 Puma 2.4 USW Stornoway Grey
I am having 265x75xR16 Cooper STT fitted to my Zu Rims tomorrow.
The truck is getting serviced today and I was going to get the dealer to reset the ECU to reflect the new tyre size. However, they have advised me that the ECU only allows the following tyre options:
2240mm - 205R16 tyre size
2458mm - 235/85R16 tyre size
2483mm - 7.60R16 tyre size
Anyone got any advice? Proud owner 110 Utility XS
Ex RR Sport HST V8
Ex Td5 90
Post #165334 30th Aug 2012 1:27pm
265/75's are, near as makes no difference, the same as 235/85's. Darren
Post #165338 30th Aug 2012 1:46pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
My 285/75 R16s make my speedo exactly read true road speed according to my sat-nav
Not sure what the ECU setting is but the truck was purchased with standard Utility steel wheel with 7.5 R16 tyres
PS - would an ECU change for tyre size mean any re-map would need to be reloaded
Post #165393 30th Aug 2012 7:04pm
Porny
Site Sponsor
No.... changing this will not affect the remap... changes are make in the IPK (instrument pack) not to the engine ECU.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #165508 31st Aug 2012 7:42am
Page 2 of 2 <12
