![]() | Home > Technical > Speedo changing with bigger tyres |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 438 ![]() ![]() ![]() |
Thanks for all the help
You can use a Nanocom also Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
265/75's are, near as makes no difference, the same as 235/85's. Darren
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 ![]() ![]() ![]() |
My 285/75 R16s make my speedo exactly read true road speed according to my sat-nav
Not sure what the ECU setting is but the truck was purchased with standard Utility steel wheel with 7.5 R16 tyres PS - would an ECU change for tyre size mean any re-map would need to be reloaded |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
No.... changing this will not affect the remap... changes are make in the IPK (instrument pack) not to the engine ECU. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
