![]() | Home > Technical > Gearbox oil filler plug leak - advice needed |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682 ![]() ![]() ![]() |
Wow! That's odd/interesting. Are you sure the oil is coming from the filler? Is it tightened to 35nm? If the filler plug looks OK, and the crush washer is good, then are the threads OK in the 'box? Try some PTFE tape on the threads?
I had a look at the workshop manual (if you want a copy PM me), and I can't see anything else which could leak in the vicinity of the filler... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
vaucluse Member Since: 04 Feb 2012 Location: SE London Posts: 185 ![]() ![]() |
Yeah - definitely the filler plug and it's tightened to 35nm.
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2509 ![]() ![]() ![]() |
I replaced both plugs with normal 20ish mm bronze hex type. Much easier to handle than those ridiculous OE plugs. Puma 110" SW
