Home > Technical > Gearbox oil filler plug leak - advice needed
vaucluse
2007 Defender 110 Puma 2.4 SW Java Black
My 2007 Puma MT82 gearbox leaks from the filler plug. I have drained it down and put in the correct 2.2L of oil and used a crushable copper washer but it still seems to be blowing by slightly. It then drips onto the hot exhaust directly below which crosses over at that point and vapourises coating the back of the truck with oil.
I've got a new plug and a solid copper washer but don't know whether I should use it or not? Or whether just to try the new plug on its own?
Don't know why this has occured in the first place. Big Cry
Anyone else had this problem? Or suggestions?
Thanks in advance,
Mark
Post #162138 15th Aug 2012 4:58pm
MartinK
Wow! That's odd/interesting. Are you sure the oil is coming from the filler? Is it tightened to 35nm? If the filler plug looks OK, and the crush washer is good, then are the threads OK in the 'box? Try some PTFE tape on the threads?
I had a look at the workshop manual (if you want a copy PM me), and I can't see anything else which could leak in the vicinity of the filler... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #162141 15th Aug 2012 5:15pm
vaucluse
Yeah - definitely the filler plug and it's tightened to 35nm.
Post #162144 15th Aug 2012 5:29pm
MK
I replaced both plugs with normal 20ish mm bronze hex type. Much easier to handle than those ridiculous OE plugs. Puma 110" SW
Post #162217 15th Aug 2012 10:12pm
