![]() | Home > Maintenance & Modifications > axle stands |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
I want to put the Puma up on to four axle stands. Is it o.k. to put the stands under the axles? 1982 88" 2.25 diesel
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Yes, although I'm not sure I'd do both ends at once. It's one of those thing that would probably be ok, but has the potential to go horribly wrong. Darren
| couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830
If possible, I also lay the wheels under the vehicle for some extra protection.
Got two pair of these 3 tonne axle stands, just arrived this morning
http://www.micksgarage.com/proddetails.asp...p;pk=C0E03 Cost me €56.38 including delivery. Thanks for the info. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Just finished painting the chassis and nether regions of the Puma. Axle stands a great benefit. Jacking up the vehicle 4 times to fit the stands in place and remove four wheels is pretty draining stuff. Having finished the painting then having to fit four wheels then jack up the vehicle with the bottle jack to remove the stands really does take it out of you. Next purchase will be that trolley jack from Halfords mentioned on one of the threads here.
The 2008 Puma is up next but not till the trolley jack arrives! 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
