Home > Maintenance & Modifications > axle stands
spudfan
Ireland
axle stands
I want to put the Puma up on to four axle stands. Is it o.k. to put the stands under the axles? 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #161816 14th Aug 2012 12:11pm
Yes, although I'm not sure I'd do both ends at once. It's one of those thing that would probably be ok, but has the potential to go horribly wrong. Darren
Post #161823 14th Aug 2012 12:27pm
Glynparry25
More than safe.... just make sure they are the correct weight rating and that the ground is level and all 4 corners are set to the same height Thumbs Up
Glyn Dog Sheep
Post #161824 14th Aug 2012 12:31pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
If possible, I also lay the wheels under the vehicle for some extra protection.
Post #161827 14th Aug 2012 12:36pm
spudfan
Ireland
Got two pair of these 3 tonne axle stands, just arrived this morning
http://www.micksgarage.com/proddetails.asp...p;pk=C0E03
Cost me €56.38 including delivery.
Thanks for the info. 1982 88" 2.25 diesel
Post #161835 14th Aug 2012 1:01pm
spudfan
Ireland
Just finished painting the chassis and nether regions of the Puma. Axle stands a great benefit. Jacking up the vehicle 4 times to fit the stands in place and remove four wheels is pretty draining stuff. Having finished the painting then having to fit four wheels then jack up the vehicle with the bottle jack to remove the stands really does take it out of you. Next purchase will be that trolley jack from Halfords mentioned on one of the threads here.
The 2008 Puma is up next but not till the trolley jack arrives! 1982 88" 2.25 diesel
Post #162109 15th Aug 2012 1:07pm
