![]() | Home > Td5 > LH back side light not working |
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208
Does the front LH sidelight work?
they're fused per side, so LH tail & side, and RH tail & side. could just be the fuse (Fuse 11, 10amp in the fusebox behind the gearstick) K109 is header C0288, which is right behind the center of the dashboard, here: Click image to enlarge If you look at the circuit diagram below, you'll see fuse 11 with the red/black wire (fusebox junction C0581-2) feeding up to the header (arrowed in purple) and feeding off to two more red/black wires ("A" and "D".... A being the feed to the LH tail light & numberplate light, and D going to the front side light) Click image to enlarge |
| dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188
yes front LH sidelight work ok
Hmmm... you could try (before ripping the dash apart) and see if there is a 12v feed at the plug under the bonnet, kind of behind and under the air filter, that feeds the read chassis wiring loom.
There's 2 plugs on it (orange and white I think), not sure which plug feeds the lights but i'm sure the red/black wire will be in there. that way you can eliminate either the "dash" end, or the "chassis/rear end"... could be a break in the wire near the light unit Have you checked the earth for the tail light? |
yes i have checked the earth for the tail light?
have 12v at trailer socket red black wire. so wire from joint A27 to A2 has OD
thanks for easy fix and thanks jim |
Cool, did you run in a new cable, or find & mend the break?
then i find time in day light hour i will look and both option
