Home > Td5 > LH back side light not working
dorstsmith2
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
Sad LH back side light not working brake light ok good earth have checked lamp RH side light working ok ?
I need to find the Header K109 so that i can trace the wires
help
Post #160293 6th Aug 2012 12:30pm
Does the front LH sidelight work?
they're fused per side, so LH tail & side, and RH tail & side.
could just be the fuse (Fuse 11, 10amp in the fusebox behind the gearstick)
K109 is header C0288, which is right behind the center of the dashboard, here:
If you look at the circuit diagram below, you'll see fuse 11 with the red/black wire (fusebox junction C0581-2) feeding up to the header (arrowed in purple) and feeding off to two more red/black wires ("A" and "D".... A being the feed to the LH tail light & numberplate light, and D going to the front side light)
Post #160321 6th Aug 2012 5:58pm
dorstsmith2
yes front LH sidelight work ok
Post #160344 6th Aug 2012 7:17pm
Hmmm... you could try (before ripping the dash apart) and see if there is a 12v feed at the plug under the bonnet, kind of behind and under the air filter, that feeds the read chassis wiring loom.
There's 2 plugs on it (orange and white I think), not sure which plug feeds the lights but i'm sure the red/black wire will be in there. that way you can eliminate either the "dash" end, or the "chassis/rear end"... could be a break in the wire near the light unit
Have you checked the earth for the tail light?
Post #160368 6th Aug 2012 8:21pm
dorstsmith2
yes i have checked the earth for the tail light?
Post #160399 6th Aug 2012 9:22pm
dorstsmith2
have 12v at trailer socket red black wire. so wire from joint A27 to A2 has OD Very Happy
thanks for easy fix
Bow down thanks the land rover
and thanks jim
Post #160408 6th Aug 2012 9:58pm
Cool, did you run in a new cable, or find & mend the break?
Post #160501 7th Aug 2012 1:49pm
dorstsmith2
then i find time in day light hour i will look and both option Thumbs Up
Post #160636 7th Aug 2012 9:28pm
dorstsmith2
Very Happy FIX
Post #161047 10th Aug 2012 7:29am
