Home > Puma (Tdci) > aircon condensed water on passenger footwell
Kraut
Germany 2010 Defender 110 Puma 2.4 SW Santorini Black
Had big puddles of condensed water on footmats and soaked carpets underneath two times this week after a two hour ride on the motorway with aircon switched on at the right footwell (passenger side). The floor panels are already rusting. Anyone here who experienced the same? Brought her to the dealer this morning to get it fixed.
Post #159340 2nd Aug 2012 8:10am
x-isle
If you go underneath the Landy, you'll find an aircon drain pipe. It's a small rubber pipe that is squeezed together to stop anything go up inside. It's stuck itself closed. Give it a squeeze and get ready to be drenched as all the water comes out.
Can't rememeber the exact location, but it's around the gearbox area.
EDIT: Here's my post when I had the same - http://www.defender2.net/forum/topic6867.html Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #159344 2nd Aug 2012 8:21am
Kraut
thanks a lot x-isle for your help
this ist probably the bad guy, found the pic in a german forum:
and this is the 'upgraded' version:
Post #159355 2nd Aug 2012 9:29am
x-isle
That's the one! Thumbs Up Craig Rogers
2007 Puma 110 XS
Post #159363 2nd Aug 2012 10:23am
Kraut
Just picked her up at the dealer, you were perfectly right. The pipe was blocked with leaves. They improved the drain pipe like on the pic above, so there shouldn't be any problem in the future
Post #159449 2nd Aug 2012 3:09pm
dgardel
Italy
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #159467 2nd Aug 2012 4:35pm
Merlin
Daniele, do you have to take the gearbox out to get to it?
Merlin
Laughing
Post #161906 14th Aug 2012 4:56pm
dgardel
Italy
Merlin
Laughing
no Merlin
the photos where taken during the clutch change. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #161924 14th Aug 2012 5:56pm
ericvv
dgardel wrote:
Sorry to say, but I have been feeling around the top of the front side of the upper gearbox tunnel to try to locate this teat, but could not find it. (And yes, my SVX does have airco Laughing )
Just want to try to get to it to make sure it stays clean as don't want the same puddle of condense water some day. Any further directions where it exactly is located? Would be very helpful.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #161929 14th Aug 2012 6:02pm
