Home > Puma (Tdci) > aircon condensed water on passenger footwell |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
If you go underneath the Landy, you'll find an aircon drain pipe. It's a small rubber pipe that is squeezed together to stop anything go up inside. It's stuck itself closed. Give it a squeeze and get ready to be drenched as all the water comes out.
Can't rememeber the exact location, but it's around the gearbox area. EDIT: Here's my post when I had the same - http://www.defender2.net/forum/topic6867.html Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
2nd Aug 2012 8:21am |
Kraut Member Since: 28 Dec 2011 Location: Westphalia Posts: 336 |
thanks a lot x-isle for your help
this ist probably the bad guy, found the pic in a german forum: and this is the 'upgraded' version: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
2nd Aug 2012 9:29am |
That's the one! Craig Rogers
2nd Aug 2012 10:23am |
Just picked her up at the dealer, you were perfectly right. The pipe was blocked with leaves. They improved the drain pipe like on the pic above, so there shouldn't be any problem in the future
2nd Aug 2012 3:09pm |
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
2nd Aug 2012 4:35pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 980 |
Daniele, do you have to take the gearbox out to get to it?
Merlin |
14th Aug 2012 4:56pm |
no Merlin the photos where taken during the clutch change. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
14th Aug 2012 5:56pm |
Sorry to say, but I have been feeling around the top of the front side of the upper gearbox tunnel to try to locate this teat, but could not find it. (And yes, my SVX does have airco ) Just want to try to get to it to make sure it stays clean as don't want the same puddle of condense water some day. Any further directions where it exactly is located? Would be very helpful. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
14th Aug 2012 6:02pm |
