Home > Td5 > Fuel pressure regulator position
peterl
1987 Defender 90 300 Tdi HT Epsom Green
Sorry for this, but not very mechanicaly minded, looks like head has gone on the td5 and i have been offered a complete engine which we may fit, but i have been told to make sure it is the same to make swap easier. I was asked if the fuel regulator was on the back of the engine as the later engines had them internally, or vise versa. What am i looking for and where should it be? Any pictures / advise would be appreciated before i committ to a new engine.i
Post #157053 20th Jul 2012 7:51pm
davew
The engine prefix is the best way of telling but failing that the later fuel pressure regulators have a pipe that runs from the front of the cylinder head to the regulator. On the earlier ones the pipe is internal.
There are also obvious differences in the location and style of fuel cooler, the EGR systems and coolant pipe layouts.
Post #157062 20th Jul 2012 8:14pm
jst
drivers side of the engine below the fuel cooler towards bell housing fixings bolts. (with lots of black fuel pipes in.out of it!) Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #157091 20th Jul 2012 10:22pm
T1G UP
You can fit a later engine in an earlier car. I did it.
Post #157101 20th Jul 2012 11:29pm
peterl
Thanks, will get out and check. I know a later / earlier engine will fit, but the guy who may fit it said a like for like swap will be easier as all the connectors etc are in place!!
Post #157127 21st Jul 2012 9:30am
