![]() | Home > Td5 > Fuel pressure regulator position |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
The engine prefix is the best way of telling but failing that the later fuel pressure regulators have a pipe that runs from the front of the cylinder head to the regulator. On the earlier ones the pipe is internal.
There are also obvious differences in the location and style of fuel cooler, the EGR systems and coolant pipe layouts. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8374 ![]() ![]() ![]() |
drivers side of the engine below the fuel cooler towards bell housing fixings bolts. (with lots of black fuel pipes in.out of it!) Cheers
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
You can fit a later engine in an earlier car. I did it.
peterl Member Since: 08 Jan 2009 Location: Pembrokeshire Posts: 312 ![]() ![]() |
Thanks, will get out and check. I know a later / earlier engine will fit, but the guy who may fit it said a like for like swap will be easier as all the connectors etc are in place!!
