Home > Maintenance & Modifications > 130 Suspenion
SGH
130 Suspenion
I am looking at changing shocks and springs on my 130 to make the ride a bit smoother. I do not carry any heavy weight and and do not intend fitting a winch or want to lift the vehicle.
I hope this might reduce the harshness fo the ride.
Any suggestions on best setup to use.
What if I remove rear center springs has anyone done this ?
Simon 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #154278 8th Jul 2012 10:35am
If you remove the middle helper spring from the back, then you'll have "110" rear suspension (HD 110, that is), and with the extra weight of the 130 would probably ride quite nicely.
On the front of 130's the factory fitment was the same as the 110 HD front (and 90 standad rear), so if you swapped the fronts to a pair of 110 standard fronts (yellow and white stripe I think) it might help. Ride height is slightly less (an inch or so, if that) between HD and SD (Standard duty)
Post #154324 8th Jul 2012 3:05pm
