![]() | Home > Maintenance & Modifications > 130 Suspenion |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6217 ![]() ![]() ![]() |
If you remove the middle helper spring from the back, then you'll have "110" rear suspension (HD 110, that is), and with the extra weight of the 130 would probably ride quite nicely.
On the front of 130's the factory fitment was the same as the 110 HD front (and 90 standad rear), so if you swapped the fronts to a pair of 110 standard fronts (yellow and white stripe I think) it might help. Ride height is slightly less (an inch or so, if that) between HD and SD (Standard duty) |
