Home > Maintenance & Modifications > wipac crystal install
Page 2 of 2 <12
IKke wrote:
Also bought these lights and installed them yesterday. They are to small to fit and rattle around in the fitting ring... they are hold in by the edge of ring. Confused
Landy is a 1986 military one
Does yours have civilian spec lights, or being military has it been fitted with the full military type lights (you push and twist to remove the complete light unit)... these may be slightly different size.
Post #151401 20th Jun 2012 7:25pm
IKke
Netherlands 1986 Defender 90 200 Tdi SW Keswick Green
I think it has civilian type lights as I had to undo 3 screws to remove the ring that holds in the light. The headlamp was considerably thinner than the previous glass wipac units that were in. Scaling the real deal.
Post #151425 20th Jun 2012 10:00pm
There are actually 2 different types of clear lenses, the wipacs and the one LR use for the SVX models.
the SVX headlamps have "crowns" inside the reflector unit.
Post #151444 21st Jun 2012 7:24am
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
For those having problems with the new units being loose in the headlamp rings
Ply the 3 tabs a bit inward before mounting and tightening the small screws.
There is a thickness difference and the original thicker lamps make the tabs ply outwards, as the rings are made from top spec stainless spring steel (sarcasm) the tabs do not have any "spring" action in them and instead of applying continues pressure, simply bend outwards.
hence if you put in the new thinner units it looks as if the rings are too wide.
2 cents
Smile
Post #151457 21st Jun 2012 9:00am
MK
Mine - LHD- have the internal reflector cup. And, yes they are better than OE headlights. Puma 110" SW
Post #151469 22nd Jun 2012 12:47pm
mine are oem LHD SVX/ICE and have the reflector cup Thumbs Up
Post #151471 22nd Jun 2012 1:07pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
bpman, at the risk of sounding like a plum, what exactly is the reflector cup? Embarassed
Post #151483 22nd Jun 2012 8:47pm
K9F
Looking at the picture of the Wipac Crystals they don't need cups as the filaments have a coating on.
With a little help from Google Schmoogle......
Reflector cups prevent direct viewing of the filament, and so minimize glare, especially if the bulb used (either by design or by modification) doesn't have a coating on the tip of the bulb. Another point to note is that 'relector cups' are not a reflector at all. Its one and only job is to block waste light and prevent glare to other road users. As stated the Wipac Crystals do appear to have a coating on the filament/lamp/bulb whatever you want to call it, this negates the requirement for reflector cups....
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #151485 22nd Jun 2012 9:21pm
taffrican
Thanks for clearing that up K9F, I suppose I could have googled it but I am still mentally scarred from any search with the word "cup" in it, especially if those "2 girls" are involved with said cup Big Cry Embarassed Rolling with laughter Whistle
Post #151487 22nd Jun 2012 10:24pm
I'll pop some photos up of the lamps tomorrow .. but basically they are silver cups/crowns built into the headlamp units
Post #151488 22nd Jun 2012 10:25pm
taffrican
Thanks bpman, the bulbs fitted in my current set up have a matt paint on the tip thus not requiring a cup, as I understand it, I think Thumbs Up
Post #151489 22nd Jun 2012 10:30pm
K9F
Thumbs Up Correctomundo! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #151493 22nd Jun 2012 11:03pm
Page 2 of 2 <12
