![]() | Home > Maintenance & Modifications > Were I can install the rear view CMOS camera? |
| Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112
Hi there!
Finally I bougth a rear view camera plus a monitor
And I would like to have some ideas were I can mount the camera and the monitor to have a good vision considering the spare wheel. Some toughts? Thanks Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
Thanks Zagato.
I forgot to put for what I need it I like to have a general vision of the back (Childrens, other low objects that cannot be seen, etc) I was thinking in the roof rack, but the view is somehow block by the spare wheel. Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2687
Stick it above the rear window washer nozzile
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
| d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044
I think that one is designed to go on a USA style number plate, so would most likely fit in the number plate area, albeit a bit of an "offset" view , or how about just under the door, looks small enough to go there.
Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
| Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982
Plug it all in and hold the camera in various postions while looking at the monitor. Perhaps stick it here and there with gaffer tape.
Merlin |
| quentin Member Since: 23 Jul 2012 Location: on tour Posts: 119
I mounted mine inside the hole in the rear crossmember, bonus is I can line the caravan up to hook onto the tow bar. eventho its offset the camera has a 120 degree view so can see everything all around anyway, including the bottom of the spare tyre on the back door which is a little annoying.
