Home > Maintenance & Modifications > Were I can install the rear view CMOS camera?
Eduardo
Hi there!
Finally I bougth a rear view camera plus a monitor
And I would like to have some ideas were I can mount the camera and the monitor to have a good vision considering the spare wheel.
Some toughts?
Thanks Eduardo
Post #148744 5th Jun 2012 4:12pm
Zagato
Really depends on what you want to look at e.g. tow bar for hitching, maybe higher up to see over trailer loads and whats behind or just to see a general area to avoid obstacles when reversing. Giving the camera angles field of view may also determine the best spot for it Thumbs Up
Post #148764 5th Jun 2012 6:32pm
Eduardo
Thanks Zagato.
I forgot to put for what I need it Embarassed
I like to have a general vision of the back (Childrens, other low objects that cannot be seen, etc)
I was thinking in the roof rack, but the view is somehow block by the spare wheel. Eduardo
Post #148792 5th Jun 2012 8:10pm
Naks
Stick it above the rear window washer nozzile Thumbs Up --
Post #148796 5th Jun 2012 8:44pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
I think that one is designed to go on a USA style number plate, so would most likely fit in the number plate area, albeit a bit of an "offset" view , or how about just under the door, looks small enough to go there.
Dj 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #148812 5th Jun 2012 10:50pm
Merlin
Plug it all in and hold the camera in various postions while looking at the monitor. Perhaps stick it here and there with gaffer tape.
Merlin
Post #148864 6th Jun 2012 10:38am
quentin
Australia 2004 Defender 110 Td5 SW Alpine White
I mounted mine inside the hole in the rear crossmember, bonus is I can line the caravan up to hook onto the tow bar. eventho its offset the camera has a 120 degree view so can see everything all around anyway, including the bottom of the spare tyre on the back door which is a little annoying.
Post #158463 28th Jul 2012 8:38am
