Home > Technical > Can you use Fellows Shredder oil to lubricate bolts?
kmac
As the topic says really. Need to lubricate some bolts to attach towball - can tighten dry or lubricate. Only oil I have that can be classed as "machine oil" is a bottle of Fellowes shredder oil.
Post #147766 30th May 2012 7:34pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I see no reason why not. However, why whould you need to unless they were very corroded? Towbar bolts are usually 8.8 grade M16s and need tightening to something like 200NM, so just wind them up!
Pete
Post #147811 30th May 2012 10:35pm
kmac
Pete
Yeah went with dry in the end - wound up to 215 Nm
They are 8.8 grade M16s
Post #147834 31st May 2012 12:26am
Most published torque figures are for clean unlubricated fasteners (unless specifically stated otherwise).
Post #147898 31st May 2012 12:29pm
