![]() | Home > Puma (Tdci) > LED lights |
I like the clear ...
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Last edited by Go Beyond on 30th May 2012 1:44pm. Edited 2 times in total |
Clear is ok if you're a teenager.... QRZ 2e0vpf
Or you are a grown up with an SVX .... ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
Sorry but Go Beyond is right the clear is ace. And no I am not a teenager.. I know one what is though que Killer90
Mobile Centre do a range of the smaller 70mm LED's as well - mine above are 95mm ....
That's good to know. I'm not saying they look bad just that they look a bit larger. Good for brightness no doubt though ![]() |
Each to their own, if we all liked the same thing it would be a boring world
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
Mine. All original clear LE Perei and all with LED's in apart from the indicators:
![]() Click image to enlarge Pete |
Honker Member Since: 26 Jun 2011 Location: St Albans Posts: 353 ![]() ![]() ![]() |
![]() Click image to enlarge Stu |
Stu's ones look like the 70mm Mobile Centre ones ...
Sure would. One reason I had a Defender in the first place a bit different not a run around ![]() |
Yep, got them front and rear in clear. Works well on black bodywork, not so sure on other colours. Stu |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
For the rear you have the choice of 95mm or 70mm.
OE size is 70mm and there is no difference in brightness between the 70 & 95mm LEDs Front is only really 70mm due to the lack of a front position light in 95mm LED. Choice of clear or coloured in both 70mm & 95mm See here for our brochure http://www.defender2.net/forum/topic12881.html Tim |
