Home > Puma (Tdci) > LED lights
Page 2 of 3 <123>
Killer90
Site Sponsor
here i am, go clear looks much better Thumbs Up
Post #147748 30th May 2012 5:53pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
mobilecentre wrote:
For the rear you have the choice of 95mm or 70mm.
OE size is 70mm and there is no difference in brightness between the 70 & 95mm LEDs
Front is only really 70mm due to the lack of a front position light in 95mm LED.
Choice of clear or coloured in both 70mm & 95mm
See here for our brochure http://www.defender2.net/forum/topic12881.html
Tim
Hi Tim do you do 70mm clear which have got DLR and if I order can you guarantee delivery by Friday.
Lee. It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #147755 30th May 2012 6:23pm
leeds
Just a word of caution, if you have LED in your indicators and tow a lot the trailer indicator lamp on your dash will not flash correctly.
Not unless Tim knows a way around that small issue.
Brendan
Post #147769 30th May 2012 7:42pm
scottish110
Scotland 2007 Defender 110 Puma 2.4 XS CSW Santorini Black
Just changed all my rear lights to clear wiped and ordered LED bulbs !!! Yes, it's the cheaper option but it look near enough the same and I only spent about £30 Smile !!!!! Will post a pic tomorrow
Post #147781 30th May 2012 8:46pm
scottish110
Wipac* lol
Post #147792 30th May 2012 9:36pm
I think they look good too. Where did you get them from? Thumbs Up
Post #147795 30th May 2012 9:56pm
sparkylee
Waiting for pics Very Happy any chance of some before in dark and after
Cheers Thumbs Up It's good to be back from the dark side
FFRR 4.2 vogue
Post #147798 30th May 2012 10:08pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I think you might be mixing two issues there Brendan. If you change the indicators for LEDs the flash rate will be wrong as the load on the flasher unit will be insufficient. If you then change the flasher unit for a solid state one which supports LEDs, the flash rate will be correct, but you'll lose your towing indicator repeater on the dash.
This is one of the reasons I've left my indicators alone, as I can't find anyone who does an off the shelf relay which supports this feature. I tow a bit and I like the reassurance of the repeater.
Pete
Post #147815 30th May 2012 10:46pm
mobilecentre
Tim
Hi Tim do you do 70mm clear which have got DRL and if I order can you guarantee delivery by Friday.
Lee.
If you call before say midday we can ship Thursday for delivery Friday. Yes we do a combined front position & DLR in actual fact I think we are the only people that do Mr. Green
Post #147821 30th May 2012 11:09pm
mobilecentre
Brendan
A number of choices to get round this
Post #147822 30th May 2012 11:11pm
dgardel
Italy
Here the goodies from TIM (Mobilecentre)
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #147848 31st May 2012 7:39am
JSG
Brendan
I'm assuming that the SVX works correctly when towing so there must be a part to fix it. John
2011 Tdci 110 CSW XS
Post #147853 31st May 2012 8:27am
The SVX indicators are standard bulbs not LED's
Post #147855 31st May 2012 8:29am
JSG
Ah, ok thanks for that. I had wrongly assumed they were LED for some reason.
Cheers Thumbs Up John
Post #147856 31st May 2012 8:30am
mobilecentre
Brendan
The SVX does not have LED indicators.
Post #147859 31st May 2012 8:44am
Page 2 of 3 <123>
