Home > Maintenance & Modifications > 1st to 2nd crunch
The Boy
1st to 2nd crunch
I have tried to search but can’t find the answer among the huge amount of posts on this subject but someone here I think said they changed their gearbox oil and in doing so got rid of the first to second crunch.
Of course this may have been some alcohol induce dream I may or may not have had in which case forget I said anything.
Boy
Post #147033 25th May 2012 2:04pm
MartinK
Boy - was it this thread
http://www.defender2.net/forum/topic2139.html?highlight=ceramic
Ceramic Power Liquid... Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #147034 25th May 2012 2:08pm
The Boy
Great! Thanks!
For some reason I thought it was an oil not an additive but now I am corrected. Anybody know if there is a UK distributor?
Thanks for the help Thumbs Up
Boy
Post #147035 25th May 2012 2:18pm
MartinK
Boy
Just had a quick search and nothing was obvious.
If we can find a vendor in the UK, I would be interested in buying some too.
Not sure about this within warranty tho...not sure LR would like it if they found something "non standard" if you were having a warranty claim... Neutral (I have already changed all fluids myself, but with "recommended" fluids only)...
My motorbike gearbox is prone to be clunky, may try it in there first... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #147037 25th May 2012 2:28pm
The Boy
Indeed yes but I am lucky (if you can call it that) as mine has just run out of warranty.
I have no idea what it cost or if they would sell direct to the UK? I have been searching but like you found nothing in the UK. Sad
Post #147038 25th May 2012 2:30pm
bob neville
No UK distributor for Ceramic.
A very kind Italian forum member Whistle shipped a bottle to the UK for me, and it does work Thumbs Up
2013 Defender 90 CSW - sold
Post #147044 25th May 2012 3:18pm
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
It may have been this thread. http://www.defender2.net/forum/topic7813.html?view=next
I was going to try some as it was very easy to crunch 1st to 2nd but decided to try some of the later spec MTF94 first (DextronII was the recommended oil for my year) and it's made a big difference. Your box probably has that in anyway though.
Post #147069 25th May 2012 5:20pm
ajps72
2001 Defender 110 Td5 SW Chawton White
There is a similar product from LIqui moly, the name is Ceratec, don´t know if there is a distributor in UK. Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #147111 25th May 2012 9:46pm
MartinK
This one, maybe http://www.liquimoly.co.uk/index.php?p=product_details&id=11 ? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #147322 28th May 2012 7:37am
The Boy
Looks interesting, might buy a couple of tubes if I can't find the anywhere I can get the Ceramic stuff. Was thinking of contacting the italians direct to see if they would send to the uk.
Post #147331 28th May 2012 10:04am
ajps72
NOOOO NOOOO dont use that one, I put it in perfectly working gearbox and after that it was hard to make any shift, I believe the antifriction also made the sincronizers (?) slip. The MOS2 might be perfect for the differentials or the transfer box.
CERATEC is the one you might be looking for.
http://www.liquimoly.co.uk/index.php?p=product_details&id=2 Augusto
Discovery 4 TDV6
Post #147450 28th May 2012 10:41pm
EWS
United Kingdom 2006 Defender 90 Td5 HT Alveston Red
Interesting thread this.
Our '06 Defender has now developed this grunch, 1st to 2nd , I just delay the engagement of the the gear for a fraction of a second or double de clutch, though I thought it was wear on the syro gear,. Will follow this thread with interest
Post #147454 28th May 2012 11:13pm
MartinK
I looked at that one, but it seemed to be aimed at Engine Oil...but then there's a thread lower down about people putting it into transmission... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #147479 29th May 2012 8:49am
wslr
Something easy to acquire and with a good track record is this:
http://ashcroft-transmissions.co.uk/index....roductId=9
Post #147603 29th May 2012 9:22pm
The Boy
Very interesting, thanks.
Q: Has anyone actually asked Ashcroft’s if they have a solution to the 1st to 2nd crunch or even if they have an opinion on the subject? I know I would be interested.
Boy
Post #147870 31st May 2012 10:07am
